I am experiencing problems with the creation of panel openings. Robot is not recognizing the definition of it. I ran the Calculation Component Registration and that did not assist.
Any suggestions as to how to solve this modelling issue?
Sameer Ramgoolam
Solved by Rafal.Gaweda. Go to Solution.
I will like the 3.2m x 2.045m contour on the top right to be an opening. I tried all methods of meodelling and non is working. The main panel (Panel 9) will be the 250mm thk raft.
Sameer
Deactivate ACIS and redraw panel:
or you can make opening in standard panel this way:
