Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
rcuapi.dll: concrete models
23 REPLIES 23
Message 1 of 24
Romanich
1418 Views, 23 Replies
I've created little macro to compare the stress-strain relationship for different concrete models. The results for some models are not what I expected.
- Effective Height Reduction Factor doesn't work and Rec model looks like linear:
- Results for Par model are completely incorrect:
- If Exponent not equal to 2 and strain at the top is bigger then Strain Ultimate Limit, StrainToStress method return -1.#IND in Pow model (for strain bigger then the Strain Ultimate Limit). IExponent equal to 2 (default value), results seems to be true:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
23 REPLIES 23
Message 2 of 24
Rafal.Gaweda
in reply to: Romanich
Thanks for reporting
Rafal Gaweda
Message 3 of 24
Romanich
Short resume after installing SP4:
Rec model - added warning message:
Par model - results are seems to be true:
Pow model - results should be close to Par model, now strain-stress relationship looks like:
Warning message has been added:
Roman Zhelezniak
Message 4 of 24
Rafal.Gaweda
These exceptions are made on purpose - to display error message below description what is wrong with model \ model data.
Rafal Gaweda
Message 5 of 24
Romanich
in reply to: Rafal.Gaweda
Dear Rafal, what you can say about Pow model?
Roman Zhelezniak
Message 6 of 24
Rafal.Gaweda
What can you say ?
Rafal Gaweda
Message 7 of 24
Romanich
I think that this part is missing (according to Eurocode 2 EN 1992-1-1:2004 p. 3.1.5 eq.3.14):
Roman Zhelezniak
Message 8 of 24
Rafal.Gaweda
That's clear that something is not cleared in rcuapi.dll 😞
Rafal Gaweda
Message 9 of 24
Romanich
After installation of the Robot 2015 two different versions of rcuapi.dll were found.
Vesrsion 27.3.0.5135 by path:
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\RESC\RC\rcuapi.DLL
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\RESC\rcuapi.DLL
This version of rcuapi.dll can be succesfully registered and added as reference in VBA.
Vesrsion 28.0.1.5354 by path:
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2015\System\Exe\rcuapi.DLL
This version of rcuapi.dll after registration gives an error in VBA :
P.S. Is it possible to share what was modified/added in rcuapi.dll in the current version?
Roman Zhelezniak
Message 10 of 24
Romanich
Ok, I found the reason of error from the previous post - Excel should be x64. But Spreadsheet Calculator works only with x32 Excel. I don't know how we can use those features simultaneously.
Roman Zhelezniak
Message 11 of 24
Romanich
Results for the Par model became strange during the increasing of the design strenght:
30 MPa:
40 MPa:
70 MPa:
Roman Zhelezniak
Message 12 of 24
Rafal.Gaweda
Oh Roman....
Need to be blocked = limit should be checked
basing on 3.14 formula the limit which can be used is 2.9 and you use 3.5
Rafal Gaweda
Message 13 of 24
Romanich
After the installation of SP2 for Robot 2015 results looks like:
Roman Zhelezniak
Message 14 of 24
Rafal.Gaweda
See : http://forums.autodesk.com/t5/Robot-Structural-Analysis/rcuapi-dll-concrete-models/m-p/5014128#M2332...
Diagram is correct.
Your data is out of range data (regarding table 3.1) which should be used in formula 3.14
For your data : point in red circle becomes point in yellow one and then algorithm returns 0 as strain becasue strain is greater than eps_cu1
Rafal Gaweda
Message 15 of 24
Romanich
Let's return to concrete models.
Model Pow (from the help - Exponential relationship for non-linear structural analysis - Eurocode 2 EN 1992-1-1:2004 p. 3.1.5 eq.3.14. Atypical) is completly incorrect.
I've created own concrete model NonLin based on the above equation.
Function NonLinStress(eps_c, f_ck, E_cm, eps_c1, eps_cu1)
'Function describes stress-strain relation for structural analysis (EC2 f.3.14)
'eps_c - compressive strain in the concrete
'eps_c1 - strain at peak stress according to Table 3.1
'eps_cu1 - nominal ultimate strain
'f_ck - Characteristic compressive cylinder strength of concrete at 28 days
'E_cm - secant modulus of elasticity of concrete (according to Table 3.1 ???)
eta = eps_c / eps_c1
f_cm = f_ck + 8 'mean value of concrete cylinder compressive strength [MPa]
k = 1.1 * E_cm * eps_c1 / f_cm
If eps_c = 0 Or eps_c < 0 Then NonLinStress = 0
If 0 < eps_c <= eps_cu1 Then NonLinStress = f_cm * ((k * eta - eta * eta) / (1 + (k - 2) * eta))
If eps_c > eps_cu1 Then NonLinStress = 0
NonLinStress = Round(NonLinStress, 2)
End Function
Please find below comparison of results:
Roman Zhelezniak
Message 16 of 24
rsousa_
Hi @Romanich ,
Any update on this subject? I saw your exceltent webinar👏 and it looked that everything was solved, but i tried and i have the same problems you report here...
Thank you in advance.
Kind Regards
Message 17 of 24
Romanich
in reply to: rsousa_
Hi @rsousa_ ,
The new version of this great dll was implemented in Robot 2021.
I hope @okapawal  and @gwizdzm  can give us more information.
Roman Zhelezniak
Message 18 of 24
rsousa_
Thank you @Romanich .
I don't have that version 😢. I'm digging this dll in visual studio (dll 64 bits and 32 bits office... ). It is super, but those errors are a mess... and it was phenomenal if you could set 2 types of steel for prestressing sections...
More information would be awesome.
kind regards
Message 19 of 24
Romanich
It seems that the BiLinear Rectangular concrete model does not work properly:
Expected results are shown in green:
Roman Zhelezniak
Message 20 of 24
okapawal
Hi Roman,
Your remark has been reported to the dev team.
Waldemar Okapa
Sr Product Owner
