Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
bartolome1819
911 Views, 1 Reply
RC Wall
Problem with a Wall reinforcement.
Please, look the file that I post here, I have four (4) walls, with the same geometry, but with different loads, completely differents for each wall; and I don't know why after I made the calculations I get the same reinforcement for all of them.
Is imposible to have the same reinforcement, you can see the Wall-Note, exactly the same distribution of bars, the same weight, the same separation, although the loads are different for each wall.
I need 4 results different for each wall, If I change the load, the reinforcement should change, please help me,
I want to know what I'm doing wrong.
Thank You!
1 REPLY 1
Based on what I can see in the calculations notes the shear reinforcement is not required and the vertical reinforcement is very low (AsL=Asr=10cm2). That's look like the minimal reinforcements in all walls.
Artur Kosakowski
