Problem with a Wall reinforcement.
Please, look the file that I post here, I have four (4) walls, with the same geometry, but with different loads, completely differents for each wall; and I don't know why after I made the calculations I get the same reinforcement for all of them.
Is imposible to have the same reinforcement, you can see the Wall-Note, exactly the same distribution of bars, the same weight, the same separation, although the loads are different for each wall.
I need 4 results different for each wall, If I change the load, the reinforcement should change, please help me,
I want to know what I'm doing wrong.
Thank You!
Solved by Artur.Kosakowski. Go to Solution.
Based on what I can see in the calculations notes the shear reinforcement is not required and the vertical reinforcement is very low (AsL=Asr=10cm2). That's look like the minimal reinforcements in all walls.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
