What is the best way to determine the reinforcement of a RC wall as in the photo? which presents bending out of the plane.
The option bending+tension/compression is ok?
Another question, in this picture (http://forums.autodesk.com/autodesk/attachments/autodesk/351/9352/1/panel%20cuts.png) in membrane forces is selected the xx direction for visualize the vertical forces in the wall. What is the diference between xx and yy in this case?.
Solved by Artur.Kosakowski. Go to Solution.
I would use this option as well.
In -plane forces in the vertical vs horizontal direction.
Thanks Arthur.
And the results of bending moment is around xx and yy? Or is the direction of the bending?
For this situation (Direction Z):
Mxx out of the panel plane as if you defined a vertical column
Myy out of the panel plane as if you defined h horizontal beam
Thanks Arthur.
For "automatic" axis apply this picture (is in the online help)?
This picture applies to "any" projection (automatic, X, Y, Z, vector). The automatic means in the direction of the local X axis of a panel.
Rafael Medeiros
