Hi Rafal and Arthur
The loads are not transferred to the RC wall module
The walls are calculated for ACI 318 parameters
The calculations for the reinforcement are inclomplete because the loads are absent
Thank you in advance
Marcelo
Try to replace the panel (wall) that you defined with number of smaller panels between each of the story (slabs). If they are actually defined like this select and export to the RC Wall design module only one of them at a time.
Hi Arthur
Thanks, I split the walls in "story pieces", but with no change in the transfer
The same panels saved as a substructure, added new loads,
the loads are transferred (NMQ) ok
I have do another example and it works for vertical, horizontal and inclined panel, also with perpendicular loads
and it works
As far as I can see there is some issue with the definition of simple load cases most likely due to the fact that their natures have been defined according to LRFD rather than ACI regulation. The easiest seem to generate manual combinations according to the ACI rules and use them in the RC Wall design module.
Hi Artur
Thanks for your time and advice
The problem persist the loads are transferred and visible in the wall-load pattern layout
Selecting one, n or all combinations takes no affect on calculations
Regards
Marcelo
Try these steps:
1. Set ACI 2002 regulation file in Job Preferences
2. Create 12 new load cases that corresponds to the ones you have in the file (mind to select subnature for live load cases) e.g. 100, 110, 120 ...900, 1000, 1100, 1200
3. Open load table on the edit tab and change load cases for the defined loads replacing 1 with 100; 2 with 200,...11 with 1100, 12 with 1200
4. Delete load cases 1 to 12
5. Renumber new load cases (this is not necessary but you may want to go back to the 1 to 12 numbers)
6. Delete old code combinations
7. Generate new ones
Corrected in Robot 2016.
