Could you please advise why my transfer beam is broken into two segments? The bending moment diagram curve is as expected but deflection drops down to zero where carried column seats on the transfer beam as if there was a column or some sort of support below but there isn't (and it's not a hanger either)- please see the attached pdf.
Thank you.
Solved by Rafal.Gaweda. Go to Solution.
Column 175 is detected as mid support. Unselect it while importing beam to RC module.
