I have a probem with the reinforcement drawings of an RC slab.
I have calculated the required reinforcement, then I have put manually the provided reinforcement, but when I try to generate drawing the result is unreadable, smudgy.
I have tryed different drawing model.
Also I would like to know if is possibile to split the reinforcement in both the directions, to achieve 4 drawings.
I don't have ASD.
Thank you.
Solved by Rafal.Gaweda. Go to Solution.
Unfortunately it is not possible.
