Good afternoon,
My RSA 2014 keeps crashing out when I am exporing out of this simple 3D model as attached. I have tried to open in repair mode etc but to no avail?
If you could assist that'd be great!
Solved by Rafal.Gaweda. Go to Solution.
I do not see any problem.
Try attached file
Rafal,
Thanks for your reply. One query that I hope you can help with.
When I am using the 'provided reinforcement' module that is linked to a Robot Analysis model, if I adjust the model, the previously designed beams then have a question mark icon, which is what I'd expect.
However, when I try to rerun rebar checks, the question mark persists?
Is it best just to delete beam then 'reimport' to this module?
Cheers
Lee
Thanks Rafal,
Hopefully one last tip! I am using the 'Typical reinforcing' button to arrange rebar, however I cannot seem to be able to introduce two layers at bottom reinforcement. I hope to use 2 layers of H25x4 = 8H25.
The input only appears lt lay the bars at the bottom and only allows increments of 3, 6 , and so on?
Another query, does Robot check that the minimum and maximum distance between bars?
Cheers
Lee
Here:
Sure it does.
Hi Rafal,
Thanks for your response. My query was for the user input 'Typical reinforcement' button if I can set two layers in this dialogue?
To set two layers of rebar in this dialogue, do you need to manually copy bars and adjust?
I have set the two layers for the 'reinforcement pattern' for the Robot Automatic design, however does not affect typical reinforcement input.
Cheers
Lee
No
Yes
Yes.
Hi Rafal,
When I do RC element update, the RC component inspector does not return a green tick as screen grab?
Cheers
Lee
Rafal,
Thanks for taking time for the video. I was hoping there was more of an automated way to update and re-calculate the rebar without having to respecify support widths, however that's life!!!!
One query,
I have opened up my model and my RSA seems to have started to work oddly with the 'Provided Reinforcement'. The tabs as per screen grab disappear and cannot seem to get these back. Also, this window disapears in total and cannot seem to re-invoke! I'm sure it is me but cannot seem to manipulate the settings to retrieve!
