Hi all
I want to export provided reinforcement for a slab to dwg. I have tried exporting drawings, but I find those dwg's hard to read. Is there a way to simplify so not every bar of a certain length gets a tag. I kinda want something similar to what i shown in the picture. Is this possible?
Solved by pevelor. Go to Solution.
Hi Rafael
Do you have tips or tricks regarding creating a more readable dwg (see attachment) or another way of showing reinforcement on a drawing in revit?
Is it possible to get the tag to be on the drawing instead of having a long line drawn to outside the slab?
Is it possible to get things on seperate layers in dwg?
Kind regards
Peder
Dear Peder,
Only when you export to ASD as demonstrated by Rafael in this link http://forums.autodesk.com/t5/robot-structural-analysis/how-to-export-slab-reinforcement-drawing-to-...
Best regards,
Aliyu A. Aziz
Hi
I am aware of the possebility of exporting to ASD, but you will not be able check deflections and cracking later on doing so.
