Hi....
...when switching between structure start and rc foundation design module the tabs/buttons in the upper screen doesn't show up (or do, but after changing from structure view to results etc. they often disappear). How can I switch then on again!?? Why does it happen anyway!?
Please see the attached picture!
Regards!
Solved by Artur.Kosakowski. Go to Solution.
Try to use these commands:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
