Discussion Groups
Robot Structural Analysis
Active Contributor
Hallvard
RC Design
402 Views, 4 Replies
12-21-2011 01:19 AM
Hi
When calculating plate/shell reinforcement I sometimes get the message "Required types are not ascribed to SLS combination. Calculations may be incorrect".
Where can I find a list of the reqiured types?
Please use plain text.
Product Support
Rafal.Gaweda
Re: RC Design
12-21-2011 02:12 AM in reply to: Hallvard
Check your settings there :
Rafal Gaweda
Active Contributor
Hallvard
Re: RC Design
01-13-2012 01:38 AM in reply to: Rafal.Gaweda
Can you be more specific?
What are the types that are not ascribed?
Your pics indicates that these types are reinforcement parameters. Is this correct?
Does this warning have anything to do with the SLS load-combinations?
Active Contributor
Hallvard
Re: RC Design
01-13-2012 01:40 AM in reply to: Hallvard
To be more specific myself; does this warning have anything to do with the loads or factors included in the SLS load-combinations?
Product Support
Artur.Kosakowski
Re: RC Design
01-13-2012 01:46 AM in reply to: Hallvard
Hallvard,
Please check the message 8 from this topic http://forums.autodesk.com/t5/Autodesk-Robot-Structural/sizing-slab/td-p/3280315
Artur Kosakowski
