Message 1 of 8
640 Views, 7 Replies
RC design crash
Hi guys,
Having a problem where running certain parts of the RC module crashes Robot (2012 64 bit version).
It crashes on many computers in our office.  But it works fine on 2013.  Is there a workaround for 2012 users?
I will send file and video in private mail to Artur.
Tony
7 REPLIES 7
Message 2 of 8
Artur,
File is uploading now.  It's a similar problem to this one;
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Crash-in-RC-module/m-p/3315369/highlight/tru...
Thanks a lot.
Tony
Message 3 of 8
Artur.Kosakowski
1. Delete all TEMP Windows files and check if there is the same issue
2. If this happens again send the crash report after typing some commend and email address in the corresponding fields.
3. Let me know that the report has been sent and what you typed (this information can be sent as a private message Smiley Happy).
Artur Kosakowski
Message 4 of 8
Artur.Kosakowski
Tony
Tony,
I have noticed that the file you sent has been saved in Robot 2013. Please mind that there is no compatibility between file formats in Robot which means that the files saved in newer versions are not intended to be opened and worked with in older ones. This is not supported operation. In your case the file you sent was created in Robot 2013 but then edited and saved in Robot 2013. The attempt to work with it in Robot 2012 again may result in the kind of the problem you described. Please make sure you use the same or higher version of Robot while working with rtd files.
Artur Kosakowski
Message 5 of 8
in reply to: Artur.Kosakowski
Artur,
I have caused the crash again and sent through the error report with my comments and my email.
Tony
Message 6 of 8
Artur.Kosakowski
Tony,
I have searched the reports we have received using your email as the filter but I'm not able to find any. Could you tell me if the crash was observed in Robot v.2013 or again in Robot v.2012 while working with Robot v/2013 file?
Artur Kosakowski
Message 7 of 8
If i use 2013 there is no crash.
If I use 2012 there is a crash.  I tried deleting Windows / Temp but no change.
The file came from a user who only has 2012 on his machine.  He is also getting the same crash, even before he sent me his file to look at.  So I do not think the crash is being caused by the file being opened in 2013.
Tony
Message 8 of 8
Artur.Kosakowski
Send me this file and indicate which beam to import to the Rc design module please. Thank you.
Artur Kosakowski
