I have problems to design RC columns with manual combinations, this option is always off. Furthermore if I select simple cases, software ignores some of them, mainly seismic cases. How could I solve this ? Thank you.
Solved by Artur.Kosakowski. Go to Solution.
Please check: http://forums.autodesk.com/t5/Robot-Structural-Analysis/RC-Column-design-manual-combinations/m-p/465...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
If you have Robot 2014 without SP 3 then yes. In fact the newest is SP5 available from Robot 2014 SP5. Try to install it and check if it solves your issue.
