Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RC Column verification: Design combination EC8
4 REPLIES 4
stroxy
567 Views, 4 Replies
1.00SPE_NEW14 (A)( SEIS. Joint X + )
How does one interprete the term of the design combination above, used in RC Column design with seismic dispositions under EC8, particularly the (SEIS. Joint X+) portion?
4 REPLIES 4
stroxy
in reply to: stroxy
Any clarifications please?
Rafal.Gaweda
in reply to: stroxy
It means:
from combination   1.00SPE_NEW14
on level  (A) - top of column
It is a set of additional forces generated by the analysis of the joint (capacity in beams connected to this node=joint required for the seismic capacity calculations of columns with respect tothe capacity of columns (currently calculated and the top if one exists) - I hope you can understand 🙂 SEIS. Joint
in direction  X
Capacity calculated for positive moment +
Rafal Gaweda
stroxy
in reply to: Rafal.Gaweda
Thx Rafal
Can ( SEIS. Joint X + ) be de-activated even with seismic dispositions checked? It seems to cause very high moments in the column. I know it is a requirement of some codes, but would like to be able to see what is required from purely design considerations vis-a-vis capacity design considerations.
Rafal.Gaweda
in reply to: stroxy
The only way is to calculate the column before calculations of beams adjoining to the node above the column. There will be no results from beams so a warning will appear as on jpg below (No. 2 and 3). The rest of seismic analysis should be done.
Rafal Gaweda
