Discussion Groups
Robot Structural Analysis
stroxy
RC Column verification: Design combination EC8
311 Views, 4 Replies
09-19-2012 05:22 AM
1.00SPE_NEW14 (A)( SEIS. Joint X + )
How does one interprete the term of the design combination above, used in RC Column design with seismic dispositions under EC8, particularly the (SEIS. Joint X+) portion?
Please use plain text.
stroxy
Re: RC Column verification: Design combination EC8
09-21-2012 09:22 AM in reply to: stroxy
Any clarifications please?
Product Support
Rafal.Gaweda
09-24-2012 02:42 AM in reply to: stroxy
It means:
from combination   1.00SPE_NEW14
on level  (A) - top of column
It is a set of additional forces generated by the analysis of the joint (capacity in beams connected to this node=joint required for the seismic capacity calculations of columns with respect tothe capacity of columns (currently calculated and the top if one exists) - I hope you can understand :-) SEIS. Joint
in direction  X
Capacity calculated for positive moment +
Rafal Gaweda
stroxy
09-24-2012 03:29 AM in reply to: Rafal.Gaweda
Thx Rafal
Can ( SEIS. Joint X + ) be de-activated even with seismic dispositions checked? It seems to cause very high moments in the column. I know it is a requirement of some codes, but would like to be able to see what is required from purely design considerations vis-a-vis capacity design considerations.
Product Support
Rafal.Gaweda
09-24-2012 04:53 AM in reply to: stroxy
The only way is to calculate the column before calculations of beams adjoining to the node above the column. There will be no results from beams so a warning will appear as on jpg below (No. 2 and 3). The rest of seismic analysis should be done.
Rafal Gaweda
