444 Views, 5 Replies
RC column design
I'm designing RC column by using robot based on ACI-code.Also the automatic combination for the structure model are generated based on the same code.However I noticed that after viewing the colum design notes that the design combination is different from the automatic combinations. Can you explain thisplease.
5 REPLIES 5
Artur.Kosakowski
Could you attach the corresponding rtd file and indicate the difference in combinations on a screen capture please?
Artur Kosakowski
in reply to: Artur.Kosakowski
Please ,find attached documents
Artur.Kosakowski
Could you send the rtd file too please?
Artur Kosakowski
i'm sorry .rtd is not supported. I can submitt it
Artur.Kosakowski
Compress it (*.zip) and then attach. Should work.
Artur Kosakowski
