I am trying to design columns and have received this error - see image attached. How do I resolve this error?
Thank youy for any assistance.
Regards
Chris
Solved by Artur.Kosakowski. Go to Solution.
Hi
You can read this post.
Depending if you defined your loads in a model and then imported them or you created loads in the RC Design module stand alone check case labels and make sure that they are different for different load cases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Hi Chris,
Try to edit (re-type as different) the names in the Label column of the Loads table (in the model) or in the Case column of the Loads table in the RC Column design module as shown on the pictures I attached to my previous answer. If you have problems with making this change attach the rtd file and indicate the column you have this problem for.
Being in the model open the loads table and display simple load cases. Switch to the Cases tab and check the Label column. Make sure that each load case has got an unique label. This is the first picture of the two I inserted previously.
Thank you Artur,
I couldn't see any problems. However, what I have found is that if I select ONE column from the geometry, screen
I can design each column one at a time. It is quite slow, but it works with no errors.
If I select more than one column, either my computer hangs, or I get the nature/subnature warning.
Regards
Chris
Attach the file and describe steps to follow to have the error displayed. I'll try to follow them to see what the possible reason could be.
