RC Column Design Warning
8 REPLIES 8
Message 1 of 9
chrismcc
715 Views, 8 Replies
I am trying to design columns and have received this error - see image attached.  How do I resolve this error?
Thank youy for any assistance.
Regards
Chris
Tags (1)
8 REPLIES 8
Message 2 of 9
HoshangMustafa
in reply to: chrismcc
Message 3 of 9
Artur.Kosakowski
Depending if you defined your loads in a model and then imported them or you created loads in  the RC Design module stand alone check case labels and make sure that they are different for different load cases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 4 of 9
chrismcc
in reply to: HoshangMustafa
Thank you for the reply. I had seen that one on the forum.  The error message i receive is about nature and subnature.  I don't know where to look to resolve the problem.
Chris
Sent from Samsung Mobile
Message 5 of 9
Artur.Kosakowski
Hi Chris,
Try to edit (re-type as different) the names in the Label column of the Loads table (in the model) or in the Case column of the Loads table in the RC Column design module as shown on the pictures I attached to my previous answer. If you have problems with making this change attach the rtd file and indicate the column you have this problem for.
Artur Kosakowski
Message 6 of 9
chrismcc
in reply to: Artur.Kosakowski
Hello Artur,
That sounds like what has probably happened.  Where do I look to resolve the problem?
When I open the design module I do see a screen about manual combinations and simple loads.  Is this where I should be looking?
The load combinations are already defined in my model, so I am not sure where it is going wrong.
Regards
Chris
Message 7 of 9
Artur.Kosakowski
Being in the model open the loads table and display simple load cases. Switch to the Cases tab and check the Label column. Make sure that each load case has got an unique label.  This is the first picture of the two I inserted previously.
Artur Kosakowski
Message 8 of 9
chrismcc
Thank you Artur,
I couldn't see any problems.  However, what I have found is that if I select ONE column from the geometry, screenCapture1.PNG
I can design each column one at a time.  It is quite slow, but it works with no errors.
If I select more than one column, either my computer hangs, or I get the nature/subnature warning.
Regards
Chris
Message 9 of 9
Artur.Kosakowski
Attach the file and describe steps to follow to have the error displayed. I'll try to follow them to see what the possible reason could be.
Artur Kosakowski
