Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RC column Design EC2 - effective creep coefficient
6 REPLIES 6
Sigo17
1469 Views, 6 Replies
Hi all,
After proceding some calculations on RC Columns module design of RSA Professional 2013 SP3 I've found some remarks that I´d like to be discussed:
1 - When running a second order analysis based on the nominal curvature method, the efective creep coeficient used in RSA calculations is the final creep coeficient and not the efective creep coeficient as is defined in clause 5.8.4 of EC2.
The use of the efective coeficient creep leads to a considerable reduction of second order efects.
Is this a RSA limitation or am I missing to activate some calculation options in RSA?
2 - About the nominal curvature method, to define both Kr and dit is necessary to know the reinforcement area. How does RSA deals with this? Is it an iteractive procedure?
Thank you.
Sílvio Gonçalves
6 REPLIES 6
Rafal.Gaweda
in reply to: Sigo17
It can be different
unless M0Eqp/M0Ed =1
If it is not the case please send us model
Ad.2 It is iterative process.
Rafal Gaweda
Sigo17
in reply to: Rafal.Gaweda
Dear Rafal,
Find the calculation note in attachment. The RSA file is over 1Gb, I'll send you ASAP without calculations.
Meanwhile, as it can be seen in the report, despite M0Epq being lower than M0Ed the creep coeficient used is the final not the efective.
Thank you.
Sílvio Gonçalves
Rafal.Gaweda
in reply to: Sigo17
Sigo17
Find below the file link  for download.
http://we.tl/jruYfCSEeK
Rafal.Gaweda
in reply to: Sigo17
It is planned to be checked by develoers next week.
Rafal Gaweda
Rafal.Gaweda
It does not work for imported combinations because Robot is not capable to recognize which QPR combination is related  to which ULS state.
It should work when simple cases are imported to RC module.
I will register it as option for implementation in future.
Rafal Gaweda
