Discussion Groups
Robot Structural Analysis
Distinguished Contributor
0 Kudos
RC BEAMS - SNIP - Area steel ?
560 Views, 9 Replies
12-21-2012 12:36 AM
Hi.. I is Prolem
I use code Snip 2.
0 Kudos
Re: Area steel ?
12-21-2012 03:39 AM in reply to: A.wikipedia
Please. I is need. Thak
Product Support
760 Kudos
Re: Area steel ?
12-21-2012 04:08 AM in reply to: A.wikipedia
Here you are.
Artur Kosakowski
0 Kudos
Re: Area steel ?
12-21-2012 05:45 AM in reply to: Artur.Kosakowski
Thanks. Athur
0 Kudos
Re: Area steel ?
12-24-2012 06:41 AM in reply to: A.wikipedia
Hi. I is prolem
Question 1. picture 1
Conver c of picture right ???
Question 2. Pticture 2
Why c=0????
I attment file picture under.
thanks
Product Support
760 Kudos
Re: Area steel ?
12-27-2012 12:39 AM in reply to: A.wikipedia
Looking at the rtd file you sent the cover is displayed as 20 mm. Could you sen the rtd file where you have it displayed as 0 mm in the calculation note?
Artur Kosakowski
0 Kudos
Re: RC BEAMS - SNIP - Area steel ?
12-27-2012 02:53 AM in reply to: A.wikipedia
Is here.
Thanks.
Product Support
760 Kudos
12-27-2012 03:19 AM in reply to: A.wikipedia
Thank you for the file. As far s I can see the 0 values are displayed when covers are locked. As you have the reinforcement frozen calculations of the beam will not change it therefore you can unmark these check boxes to have the correct value displayed in the calculation note.
Artur Kosakowski
0 Kudos
12-27-2012 03:50 AM in reply to: Artur.Kosakowski
Thank Artur.
But If I not Fixed. As (robot) > As( hand).
Product Support
760 Kudos
12-27-2012 03:57 AM in reply to: A.wikipedia
1. Calculate beam with the fixed covers
2. Edit the value of covers in the calculation note or
2a. Freeze the reinforcement generated for the fixed covers
2b. Calculate the beam with frozen reinforcement again to have the 20 mm cover displayed in the note.
Artur Kosakowski
