Discussion Groups
Robot Structural Analysis
Участник
Re: RC Beam module – calculation error
04-11-2012 05:23 AM in reply to: Artur.Kosakowski
Please use plain text.
Product Support
Artur.Kosakowski
04-11-2012 05:33 AM in reply to: Участник
Please select the EN database and press the V icon above. Press OK. Calculate the beam - do you have the same issue with generation of the main bars?
Artur Kosakowski
Участник
04-11-2012 05:38 AM in reply to: Участник
The same issue with any default reinforcement database.
Product Support
Artur.Kosakowski
04-11-2012 06:21 AM in reply to: Участник
I'm sorry to ask again but could you make two more tests please?
1. Are main bars generated when you use standard settings?
2. Are they generated for a rectangular beam?
Artur Kosakowski
Участник
04-12-2012 12:00 AM in reply to: Участник
Sorry to admit but ‘*.xml’ warning message popped up just after I pressed ‘Reinforcement pattern’ icon.
Is it possible to reassign missing path to ‘*.xml’ file without reinstalling the program?
Product Support
Artur.Kosakowski
04-12-2012 12:49 AM in reply to: Участник
Please try to register syspath.dll
regsvr32 "c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\syspaths.dll"
or
regsvr32 "c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2012\x64\syspaths.dll"
Please make sure you run Command Prompt as admin (available under RMB)
Artur Kosakowski
Участник
04-12-2012 01:31 AM in reply to: Участник
It worked!
Thank you so much!
