Please help me configure the steel in a beam design shown in the attached file. Thanks in advance.
Solved by Artur.Kosakowski. Go to Solution.
You may try to delete bars 9 and 11 and then select and copy bar 10 downwards.
I do not want to do it manually.
I want it happen automatically by configuring something in beam calculation option. Can we do?
I'm not sure if I understand you correctly. You wrote that the automatically generated code combinations are not as required in your country. If that is the case then you have the following options:
- you can create a new regulation file (or edit the existing one) to generate code combinations that match the requirements. Then you import simple load cases from the model to the RC Beam design module.
- as above but you generate manual combinations in the automatic way and then you import them instead of the simple load cases
- you create combinations in a model manually and then you import them to the RC Design module.
Please look at the attached files to see clearly my problem.
See the attached pictures.
