I have an analysis for a beam with moments in both axes (My and Mz)
When calculating the RC-members required reinforcement; in the results windows; the table displays the Design My and Mz design moments. However, the Mz column values are all CERO.
Can the RC beam design module handle biaxial bending?
Solved by Rafal.Gaweda. Go to Solution.
Hi
By default, ARSA will calculate for biaxiale. Please find the attached file (Biaxial_2). If you want to change biaxiale option to unidirectional, please find the attached file (Biaxial_1)
Hoshang ,
He is talking about Required Reinforcement module, not full.
Hi Rafal
You are right. I'm sorry.
