Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
Re: RC beam/column warnings & pinned linear joint problem
09-17-2012 05:47 AM in reply to: Opel5
Opel5 wrote:
Thanks for the input Rafal :smileyhappy: I've tried releasing "Edge 4" of the panel 459 as "pinned-pinned" but it seems to only release all edges as pinned, and after applying the release there is no was of checking which edge of an object has release conditions. Is it possible to specify only 1 linear edge release at the base of the stairs panel?
Example
Rafal Gaweda
Please use plain text.
Product Support
Rafal.Gaweda
09-17-2012 06:13 AM in reply to: Opel5
Scott
Could you give a bit more guidance please on how I acheive the above please? I had nodes all over the building to start with but a lot of them have been removed during FE meshing, FE mesh removal (for editing), and panel alterations. I have quite a few cases where the wall panels seem to clash with the embedded RC columns and assumed Robot could distinguish between the two rather than having to manually (and painfully) separate panels from columns at all intersections?
See below.
Look also at difference between results.
Rafal Gaweda
Valued Contributor
Opel5
09-25-2012 12:15 AM in reply to: Rafal.Gaweda
Hi Rafal,
I've finally got a chance to go back and follow your advice concerning below:
. In practise the reinforcement will be lapped along edges, so is there a way of releasing the nodal corner only at the wall corner - slab?
No you can apply linear releases to panels. Divide \ create shorter edge nead the corner and apply there releases
But can't seem to find a way of neatly dividing a small L-shaped peice of the roof slab panel at the outward wall corner in the attached screenshot to remove the reinforcement spike?
Product Support
Rafal.Gaweda
09-25-2012 08:10 AM in reply to: Opel5
Scott
Divide WITH node generation, then select panels edge.
Rafal Gaweda
Product Support
Artur.Kosakowski
10-04-2012 06:58 AM in reply to: Rafal.Gaweda
Scott,
The procedure as requested.
Artur Kosakowski
Valued Contributor
Opel5
10-04-2012 07:25 AM in reply to: Artur.Kosakowski
Thanks Artur :smileyhappy: Got the hang of the procedure now
