Looking at the SLS paremeters for slab analysis. I have a few questions. I am used to utilising SAFE for deflection analysis of my flat slabs; however I am intrigued about the capability of ROBOT to offer a complete design solution.
I note that in the BS8110 reinforcement parameters a "ratio of loads:long-term to varaible" value can be edited.
Is there any way of assigning the long term/short term to a specific load? and also is there a mothod of attributing a certain percentage of a certain loading case to long term or short term laoding parameters. I.e. could I attribute 20% live as long term sustained loading and 80% to instantaneous short term loading?
Many Thanks,
Andrew
Presumably, if I set 30% of load to be be long term sustained then this will result in all of the loading in the SLS combination being treated as long term?
Do I need to manually go through my unfactored loads and calculate how much of it needs to be long term? What happens is I am to expect some long term live in one area an not another?
You can also determine the ratio of variable loads to long-term loads.
Variable loads may be divided into short-term and long-term loads. The long-term to variable coefficient specified in the Ratio of loads is used to split variable loads into a short-term part and a long-term part according to the following formula.
variable load = (1 - c) * variable load + c * variable load = short-term load + long-term load,
where c is a coefficient of the participation of long-term loads in variable loads.
