Discussion Groups
Robot Structural Analysis
stroxy
Raft with Ground Beams
206 Views, 1 Replies
12-30-2011 05:30 PM
Hi
  1. What is the difference between elastic ground bars from the geometry>additional attributes menu and elastic linear support from the geometry supports menu?
  2. If I have a raft with integrated beams, do I assign elastic supports to the raft and then additionaly assign elastic ground bar properties (or elastic linear support) to the beams?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Raft with Ground Beams
01-01-2012 11:52 PM in reply to: stroxy
1. The later can be applied to the edges of the panels only.
2. No, this will 'double' the elasticity along the beams.
Artur Kosakowski
