Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Raft Foundation - No convergence with uz+ uplift
2 REPLIES 2
RRufino
685 Views, 2 Replies
Hello All,
I've read a lot of posts and tips here but i could not solve my problem. Can you give me some help?
It's the usual stuff, raft foundation model (forces imported from other mothel), allowing Uz+ uplift leads to non convergence.
I'm rushing with this project 😞 if you can look to file in attachment i would apreciate
RR
2 REPLIES 2
Rafal.Gaweda
in reply to: RRufino
Set all simple cases as auxiliary
Change both tolerances of remaning combinbations for nonlinear calculations onto 0.001
Rafal Gaweda
RRufino
in reply to: Rafal.Gaweda
Thanks, i've thought to do that (set all simple cases as auxiliary) because in this particulary model i do not have springs in tension to combinations (i've tested it with "none" on uplift option). But doing this i'm not accepting that can exist tension on simple cases? Subavaliating compression on springs due to combinations?
Thanks Rafal
