Hello there,
I am designing a raft foundation usign autodesk robot 2014 and i am facing some problems
First question:
Whats the difference between defining the stiffness of the soil Kz in the thickness of the plate or as a support?
2nd question:
what is the proper way to define the soil stiffness as a support? is it defining it as a Uz support at different points at a certain distance??
Third question :
when defining Kz in the thickness of the plate, after running the analysis a warning message appears "no supports" is it ok? if not what is the proper support to define for a raft foundation?
Thanks in advance,
Ali
First option - as a results you get soil reaction map.
Second option - as a results you get nodal reactions
Your choice but I suggest first option mentioned above
it is OK, but remember to block UX, UY displacements somewhere
ok great answers for my questions thank you
I am facing another problem, when calculating the required reinforcement a calculation status appear "incorrect material"
the file is attached
Thank you,
Ali
