"System.Runtime.InteropServices.COMException (0x80040154)"
11 REPLIES 11
Message 1 of 12
mail2mr1
3680 Views, 11 Replies
When I try to make a section selection from the database by opening database sections to get properties by using menu items.. geometry..properties..sections, I receive the following error:
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5C257DA9-418F-11DF-BDA4-002264AF06AC} failed due to the following error: 80040154.
Entering "continue" does not help.
Can anyone help me?
Bill
11 REPLIES 11
Message 2 of 12
Artur.Kosakowski
in reply to: mail2mr1
Could you make the screen capture that illustrate this situation please?
Artur Kosakowski
Message 3 of 12
dimogrec
in reply to: Artur.Kosakowski
I' m having the same issue with RSA2012 pro 64bit. I also have RSA _pro 2011 32bit installed and i don't have this problem.  I'm running Win7 64bit. In the attachment you'll find a screen capture and a text file with the error details
Message 4 of 12
Artur.Kosakowski
in reply to: dimogrec
Please download and install the indicated updates from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 5 of 12
dimogrec
thanks. It worked
Message 6 of 12
Hi @Artur.Kosakowski,
I am getting the same error as shown in the screenshot. I am using RSA 2015. I get this error while I run my script in Release mode, but in Debug mode, there is no error and it runs smoothly. I am trying to extract results of a ROBOT analysis through a C# code
Message 7 of 12
rhlkochar
in reply to: rhlkochar
@Rafal.Gaweda Your inputs would be most welcome
Message 8 of 12
Rafal.Gaweda
Message 9 of 12
rhlkochar
in reply to: Rafal.Gaweda
Hi @Rafal.Gaweda,
I went through the thread you linked me to, but I couldn't quite understand what you meant. Could you please elaborate? Thanks 🙂
Message 10 of 12
rhlkochar
Hi @Rafal.Gaweda, The curious thing is other parts of the code- model creation, meshing , application of loads, etc work smoothly. This error is thrown only when I try to perform extraction of results. I can't seem to figure out why
Message 11 of 12
Rafal.Gaweda
Hi @rhlkochar
I meant posts 8 and 11.
BTW if You are extracting results via queryparams keep in mind that queryparams are only 64bit and therefore addin should be 64bit.
Rafal Gaweda
Message 12 of 12
rhlkochar
Hi @Rafal.Gaweda, Works like a charm! Thanks!
