Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
"Stress or strain ratio" - PSI calculation
2 REPLIES 2
Edgaars
341 Views, 2 Replies
I ran into some problem calculating PSi ratio for steel cross section class. In stress analysis for bars the stress diagram shows those stresses that i have to use in formula which are accurete with my calculations, however calculating PSI ratio (4.72/10.67=0.44), it's not equal to RSA Detailed rasults given (-0.57). I am attaching robot file for further inspection.
So my question: am i doing calculations right or the configurations for analysis are incorrect?
Tags (2)
2 REPLIES 2
Artur.Kosakowski
in reply to: Edgaars
Robot follows the recommendations of CTICM
Artur Kosakowski
Edgaars
in reply to: Artur.Kosakowski
Thanks for your reply, Artur!
