Discussion Groups
Robot Structural Analysis
70 Kudos
"Problème d'Exécution" Message.
114 Views, 3 Replies
01-17-2012 03:06 AM
At the sturm verification (static are ok , and modal finshed ) , the calculation stops and i have this message "Problème d'exéution" !
What is the cause of this, and how to correct the model in consequence.
Its top urgent.
thx
Product Support
326 Kudos
Re: "Problème d'Exécution" Message.
01-17-2012 03:17 AM in reply to: faisal.aaouatif
Please attach the model. Use Save as without results and compress to ZIP to reduce the size if it's too big.
Pawel Pulak
70 Kudos
01-17-2012 04:41 AM in reply to: pp2008
after compressing the file , it still too large ( more than 6 MB)
what can i do
70 Kudos
01-17-2012 05:14 AM in reply to: pp2008
After moving the model to another station with more memory capacity ( C:/ ) , ive got no probleme !
thank you anyway
