Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
"lack of some section parameters"
5 REPLIES 5
jpn9
523 Views, 5 Replies
I'm attempting to do steel frame design using RSA 2012. The calculation generates an error that says "Calculations have not been performed for members ( 1to31) due to lack of some section parameters". Can someone give me guidance into how I might solve this problem. Thanks
-James
5 REPLIES 5
Artur.Kosakowski
in reply to: jpn9
What are the sections you assigned to these bars? Could you attach the compressed rtd file so that I could have a look at it please?
Artur Kosakowski
jpn9
in reply to: Artur.Kosakowski
Absolutely. Most of my sections were TS2x2X.125 I believe. I have loaded these sections but it still says parameters are missing. Thanks for your prompt reply
-James
jpn9
Apologies. The last attached file had undefined sections. This attachment does not.
-JN
Artur.Kosakowski
in reply to: jpn9
The warning is caused by the design of the group with the search for best matching sections from DL, DLL and DLS double angles families. In the AISC 13.2 section database the values of Ix and d Iz are incorrectly set as 0s. We will address this issue but in the meantime use the DL, DLL and DLS sections from the AISC 13 database instead please. The way of declaring it in Job Preferences as well as the way of modifying the Sections in the group definition is shown on the attached picture. In addition I'm attaching the file with described above changes.
Artur Kosakowski
Artur.Kosakowski
in reply to: jpn9
As this issue has been addressed in SP3 it is enough to download and install it instead of using the workaround I proposed in my previous post.
Mind to select the correct version of the SP (Professional or Standard version as well as 32 or 64-bit OS).
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
Artur Kosakowski
