I am having this error message pops up "encountered an improper argument" when trying to save some files on specific location to my computer.Finally file is saved but the message irritates me so much.
I have win7-64 with ARSAP2013. So the question: How to fix that.
Thanks in advance.
Solved by stosto6666. Go to Solution.
I confirm this issue when working in English language version of Robot.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
We will try to investigate what is causes the display of this message but we need the files it happens for as well as the exact step by step descriptions of actions to follow. What are the regional settings of Windows?
Hi Artur,
Regional settings of Windows is Russian. It happens with in any file.
Roman Zhelezniak
I confirm this. I mean what Romanich said in message #4. When You try to save any file in for example: C:/ My Documents/My Projects/....../ it happens. When You open the same file and try to save on Desktop no problem at all.
Any chance for the following test on your computers:
1. Change regional settings to e.g. English
2. Create a new user with no Cyrillic letters in its name
3. Use Robot and check if you still have the same situation
My user name already in English, but when I change settings for Canada - problem disappeared. Then returned it to default - also disappeared. Very interesting.
Roman Zhelezniak
Artur.Kosakowski wrote:Any chance for the following test on your computers:
I do 2 and 3 without 1. It works. All folders through path to the exact file must have no Cyrillic letters.
Thanks.
Thank you. Most likely taken that they when I encountered an improper argument.
3. Use other Font and check if you still have the same situation
