ingeniero_mena
2035 Views, 4 Replies
Push Over analysis
Hi all.
i need some one to check why the PushOver analysis does not converge.
i have the RSAP 12 with SP5
maybe some details i am missing. it is a 2dimension frame.
regards
4 REPLIES 4
Hi Rafal,
can you check my concern about Push Over analysis in the example i attached.?
regards
Hi Angel,
Why do you think it does not converge ?
Rafal Gaweda
Hi Rafal,
i forgot one thing. can you put a Hinge and then run again. maybe i am missing some step.
thanks
Take a look at attached model - it converges.
Maybe you mean nonconvergence for eg of case 1 with "Structure Collapse" set - it is correct
1A. The Structure Collapse Criterion
Analysis performs until the divergence of the iterative process is reached.
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-43CF18F4-F8A4-4800-B031-1F3128665253.htm
Rafal Gaweda
