I am trying to extract a table from the punching shear tab, i have done it before with support number, loads q and qadm, critical perimter etc.. how do i view this as a table solely? I cannot recall how to do it,
Advice is greatly appreciated
Solved by Artur.Kosakowski. Go to Solution.
You can either select the cells and paste them directly to e.g. Excel (mind that the names of the columns and rows have to be added manually afterwards as they are not copied via clipboard) or copy the corresponding part from the calculation note (Results > calculation note).
