I've asked this before but am still a little unsure. I'm doing a hand calculation for punching shear on a flat slab. I require the shear force at a support, only I need the shear force at the column edge (on its perimeter).
I have defined the support as a circular column applied at a particular node. The shear force at that node is very small but the shear force at a node away from the column is particularly high. What is the best way for me to get the shear force at the column perimeter? I presume this is what I require.
I've attached an image of the structure with the shear force results map if that helps to visualise the problem.
Thanks again!
I think the better approach is to check the value of forces in the support (column) and the difference in values of bending moments at the opposite sides of it.
so the total shear force for shear punching at a column would be:
(Shear force at column centre) + (moment divided by distance from application to column centre)?
greetings Mr Artur
is there is still a need to do what you have described in this thread in RSA 2015
specifically talking about getting the correct punching shear stresses
or already in RSA5 "punching" from "plate and shell reinforcement "include the unbalanced moment in shear calculation
thank you very much
It is included in the punching verification done in the RC Slab Provided reinforcement module.
