Discussion Groups
Robot Structural Analysis
3 Kudos
Provided Reinforcement design for divided column
411 Views, 7 Replies
09-26-2012 05:23 AM
How does one design a column which has been divided into two (or more) columns in the analysis module (because of connecting beams mid-height in column, or column spanning multiple stories)  in the RC design module.
I assume you can take a section and input the real length of the column in the buckling analysis but how does one factor in columns end moments, etc.??
Product Support
1,301 Kudos
Re: Provided Reinforcement design for divided column
09-26-2012 08:33 AM in reply to: stroxy
You have to divide such column into parts.
Rafal Gaweda
3 Kudos
09-26-2012 09:27 PM in reply to: Rafal.Gaweda
So if I have say a 6m column divided into 2 parts for analysis.  In designing the column I will design both parts as separate columns and enter efffective length  factor * 6m as the buckling length for each part ?
Product Support
1,301 Kudos
09-27-2012 08:08 AM in reply to: stroxy
Decision is yours but IMHO if you are talking about right hand side case (below) I would suggest to use 3m as column length. Left => 6m.
Rafal Gaweda
3 Kudos
09-27-2012 08:17 AM in reply to: Rafal.Gaweda
Thanks Was talking about LHS case
3 Kudos
09-27-2012 08:19 AM in reply to: stroxy
How did you get buckling shapes to show?
Product Support
1,301 Kudos
09-27-2012 08:36 AM in reply to: stroxy
FEM Buckling analysis
Rafal Gaweda
3 Kudos
09-27-2012 10:18 AM in reply to: Rafal.Gaweda
Thanks once again!!:smileyvery-happy:
