Greeting
i have been analyzing this one way ribbed slab in robot structure and when i go to design of ribs in the RC design , a huge value for the required As = 5.02 cm^2 (4T14) appears instead of 2.2 cm^2 (2T12) for the negtaive moment
but when i browse the theortical abmin diagram of the rib it shows strang value that shown below in the self-explain picture
i think this is incorrect , so please help how i can fix this ?
Solved by Artur.Kosakowski. Go to Solution.
Thank you for notifying us about this situation. The difference is due to the value of bw in the formula:
(10-3) Asmin = 3*sqrt(Fcd[PSI])/Fyd[PSI] * bw*d, not less Asmin = 200/Fyd[PSI] * bw*d
For a T beam with the flange under compression bw should be min (flange width or 2* thickness of web). Currently Robot incorrectly always takes the width of the flange.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
thank you for your care
There is another thing you have to take into consideration , that is (bw) will be taken as 2*bw or beff which is smaller only in the case of statically determinate member and the continuous beam is statically indeterminate then this rule is not applicable according to ACI -318R -08 am i right ?
i wish you make an update for this problem that so i can download it because currently i am preparing my graduation project .
a picture is enclosed form the ACI
Corrected in SP3 for Robot 2015.
