Is there a properly manual for Spreadsheet Calculator? I know the two videos on youtube by Tomasz Fudala, but I am sure that more could be done.
Manual?
Just fill data with cells with blue fonts.
Use help.
Thank you for your prompt answer but I'm sorry, it isn't helpful to me.
Which cells with blue fonts do you mind?
Du you mind I shall use the help of the Spreadsheet Calculator? This help seems to me more like a list of the SC commands than a help which explains the use of SC. There are RSA manuals that show the use of RSA with examples, I mind something like that.
I see what you mind.
I'm thinking of doing a Spreadsheet from a blank site.
I have to size stackers, reclaimers and machines like these. The codes to dimension them are the 'rules for the design of mobile equipment for continuous handling of bulk materials', known as FEM code as well. Neither RSA nor the most of the commercial programs design according to this code. That minds I have to extract the results from the calculation (mainly tensions and forces), introduce them in a Spreadsheet I have made with the formulas according to FEM and check the viability of the results according to the FEM rules.
Spreadsheet Calculator could automate the most of these handmade-steps, I would need to create a new Spreadsheet keeping in mind the FEM code.
Good luck.
My recommendation : Use API, use examples http://forums.autodesk.com/t5/Autodesk-Robot-Structural/useful-addins-for-Robot-API/td-p/3899448 or code from them.
I can help you with API, no problem.
