The newest addin from Autodesk Labs - Project Octopus that allows designers and engineers using Autodesk Robot Structural Analysis to seamlessly access data and results with Microsoft Office Excel. To know more about it please use this link.
For the first look this is the Excel_Formulas.xlsm from the 2014 SDK.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Rafal.Gaweda. Go to Solution.
For some reason all the Robot files under the Example folder does not work, it is empty!!. when you click on the file you can see the structure in the preview but there is nothing in the file when it is opened even in the repair mode.
C:\ProgramData\Autodesk\Examples\Project Octopus\RSA
Hi Rafal,
as you can see in the following picture, when I run Excel_Formulas of project Octopus, I have the message "RSA is not open" but, as you can see, RSA 2014 is opened.
Whats wrong? Any registry option? I've installed on my workstation contemporary RSA 2012, 2013, 2014 and 2015 beta.
Thanks in advance for your reply and merry christmas.
cool tool but whats the difference between this and Robot Spreadsheet calculator?
andy
Hi guys....
No Wel ?
Seems only to give formula for Wpl.....
will the Octopus get some more tenticles and allow access to elastic section modulus? 🙂
Tony
Does it work the other way round? I mean if you modify lets say the position of a node in excel, will it change in ROBOT?Do the two programms interact?
Thank you.
The programs interact, but it's more like Excel can extract data and information.
If you see the formula in Excel it looks like this;
The X co-ordinate of node 1 is -9m. If you just typed 9 into the cell it would over write the formula.
You'd need to use VBA if you needed to update Robot out of Excel.
Tony
At this time the team is reaching out to 64-bit users only. There are enough people using 64-bit so that the team can get the feedback about the technology preview that the team needs.
32 bit?
They'll be expecting support for MS DOS soon........
Time to upgrade 🙂
I get the attached error image attached while opening the file c:\Program Files\Autodesk\Project Octopus\Framework\ASC.vsto..Please comment
