Problems with vertical elastic support
1 REPLY 1
266 Views, 1 Reply
I'm running a non-linear analysis model with elastic supports in Z-axis. All the supports are extremely stiff (atm all of them at -100000kN/m) and yet my model does not converge even for a simple dead load case. I tried fixing a single point within the structure, but it didn't fo the trick. The structure is a gridshell with supports more or less evenly distributed around its perimeter beam. Also, each support is located at the bottom of a dwarf column which is fixed to the edge beam. RX, RY, RZ remain fixed throughout and the until I input stiffnesses in the Z direction the model converges.
Any help would be very much appreciated!
Ewa
1 REPLY 1
Artur.Kosakowski
Try to set the full Newton-Raphson method (the green one)
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Non-linear-Static-Analysis-Parameters/m-p/36...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
