Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problems with saving results
9 REPLIES 9
Message 1 of 10
805 Views, 9 Replies
I'm experiencing problems with saving results. It's RC flat slab and after running the analysis, checking deflections for required reinforcement I then define the provided reinforcement and re-run deflection calculations. After doing that I save the file. Most of the time after re-opening the file there are no results for provided reinforcement. That means I have to define column strips etc all over again and run calculations. Next time I open the file - no results again. I tried using 'save as' options, also used Robot 2013 instead of 2014. Nothing works. Please advise.
Regards, Wioletta
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
Could you send me the sample file and the step by step description of actions to follow please? Thank you.
Artur Kosakowski
Message 3 of 10
in reply to: Artur.Kosakowski
Hi Artur.
Apologies for late reply but things have been very busy recently, partially because I kept 'loosing' my results.
The attached is one of the files affected. The sequence is: I open the file run calcs, provide reinforcement accordingly - run verification for deflection results, save the results under new file name, close the file. The next time I open it - no provided reinforcement or results, but there are results for required reinforcement not always though. So I start again... and then again...
Luckily somehow I managed to save couple of files with the results but I didn't do anything different with these. Same sequence.
I also had my Robot reinstalled.
It's a first time I'm having this kind of problem with Robot.
I hope the above makes sense.
Regards, Wioletta
Message 4 of 10
I canot attach the file. Zip file is not going through and not zipped is to large (saved under no results option)...
Is there any other way I could send it to  you?
Wioletta
Message 5 of 10
Artur.Kosakowski
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Sending-bigger-files/td-p/3795062
Please add step by step description of actions to follow to reproduce this situation. Thank you.
Artur Kosakowski
Message 6 of 10
I have changed the zipping settings (from 7zip to zip). Please find attached.
The sequence as described above.
Message 7 of 10
Artur.Kosakowski
Could you attach the file again without % in the name please? Otherwise I'm not able to download it.
Artur Kosakowski
Message 8 of 10
Message 9 of 10
Artur.Kosakowski
I followed your description and after calculating required and provided reinforcement I launched verification with the stiffness update for COMB 3 being on the Slab provided reinforcement layout for all 4 slabs one by one. Then I saved the file under a new name and closed Robot. After opening the file again I can see that the results are still there. I will send you the file I saved separately as it is too large to be attached to this message.
Artur Kosakowski
Message 10 of 10
Thank you very much for your time.
I repeated the same exercise couple of times and it seems to work. I have no idea what the problem was but I do hope that it won't happen with my next project.
Thanks again.
Regards, Wioletta
