Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problems on reinforcement of 3D solid structure ,pls help
4 REPLIES 4
1143 Views, 4 Replies
I'm working on 3D volumetric structure which is shonw in attached figure. My serious trouble is how can reinforce in this model when i'm trying to design by using "Provided Reinforcement of RC Elements" so the result is the pop-up window shows that "The element will not be included in the provided reinforcement modules.The material defined for this element is not concrete.". So, how could i solve this problem ?
4 REPLIES 4
Artur.Kosakowski
The RC Design modules can only be used for surfaces (panels) and bar elements (beams/columns). Solids are not supported.
Artur Kosakowski
Is there anyway to convert this solid to panels ? If not, how hsould i do to finish the reinforcement or any your suggestions for me, pls.
Artur.Kosakowski
No, there is not. You should create the model using the shell model type instead.
Artur Kosakowski
Got it. Thanks for your suggestion.
