dans le calcul d'une starion de traitement d'eau :
j ai modéliser une poutre (courone au dessu des voiles ) mon probleme est des determiners le ferraillage correct de cet poutre les armatures doivent etre dimenstione dans le sens z de la section (Mz non pas My )
Solved by Artur.Kosakowski. Go to Solution.
For the RC beam module the support detection is done only in the global Z direction therefore you have got two options available:
1. Use the RC Member Required Reinforcement module
2. Rotate the entire model 90deg about the global Y axis and redefine the loads. Them The global Z will became what is now the global X so taht you will be able to export tow longer beams (bars 3 and 5) to the RC Beam design module. Then do the same but rotate about the global X for the shorter one (bar 1).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
