Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
problem with offset
2 REPLIES 2
1407 Views, 2 Replies
problem with offset
hi
i made tow simple models tow columns ,one beam and a slab but i used offset in one of them the there were a big differance in the results see attatched image
2 REPLIES 2
Artur.Kosakowski
This is as expected because the stiffness of the slab with beam with the offset is larger than the one with no offset. In addition use of offset causes generation of large axial force in the beam and reduces its bending. See:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/T-slab/m-p/3185418
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Beam-offsets/m-p/3332921
Artur Kosakowski
thanks
