Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with modal analysis
5 REPLIES 5
StructuralSilver55
1388 Views, 5 Replies
Hi!
I continued building my model (attached), but when I try to run the modal analysis to apply sismical spectrum, RSA gives me the next problem : 3060 execution error . I have one advice about instabilities during the analysis, I have tried to solve them dividing the mesh.. re-meshing the place where I have the problematic node... but the problem continues and every time is a different node!
I've been trying to solve this problem for a long time, and I don't know why a node in the middle of a mesh gives a instability problem.Smiley Sad
Thank your very much for your help.
Click here to obtain model.
5 REPLIES 5
Use Skyline solver
Rafal Gaweda
Thank you very much Rafal, but i continue havin inestability problems, how can I solve them?
¿Why changing the solver the analysis run? Could your explain it?
Thank you!
I continue having problems with the model, when I try to print strenghs in the walls (in global Z direction, MPa), they are not very logical, i can see tensions in some parts of the walls (they are not very logical because I used linear relases for all rotations between walls and horizontal shells) .
Could you help me with this?
Thank you very much!
athurD
in reply to: StructuralSilver55
for you.
But there are no supports in XY direction in your model.
Try my file, you can use any solver you want
Rafal Gaweda
