Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Problem with loads on the construction
4 REPLIES 4
456 Views, 4 Replies
At the moment I am busy with a project of a building with 15 levels. And I want to know if the building can handle its own weight. I have sent the project file from Revit Structure 2014 to Autodesk Robot 2014 with only the dead loads of the floors. But after the calculation I can not get a good image of the dead loads on the building with the ''maps'' tool (Results > Maps).
Can you explain to me what I am doing wrong? And how I put the other loads on the construction in this model?Smiley Embarassed
For the files see: https://www.wetransfer.com/downloads/69c60b3430495199a8809adc5d57d91a20141001150304/a85a29
4 REPLIES 4
Rafacascudo
Results/ maps is used to see the forces/moments results for Panels(slabs , walls)
To see which loads are applied for a load case ,use View/Display.../Loads
Rafael Medeiros
Artur.Kosakowski
In addition to
Artur Kosakowski
in reply to: Rafacascudo
Ok, the dead loads of the concrete floors are visible now.
But the dead loads of the walls are still not visible. I have put the dead loads on the walls with (load definition > bar > uniform load) of the construction. I already looked at the settings by View > Display > Bars and Loads, but nothing became visible.
Can you please help me how I get those weights visible?
Rafacascudo
Is it " dead loads" due to the wall weight applied on beams(bars) , or is it the wall self weight??
- Self Weight of all modelled elements can be generated automatically by the program.
- Wall "Dead load" like wall finishing can be applied to a structural wall ( panel ) on Load Definition/Surface/uniform planar load
- if it is a brick wall(non structural) ,it can be aplied to bars or  slabs(panels) as linear loads
Rafael Medeiros
