Discussion Groups
Robot Structural Analysis
Valued Contributor
rodainnajjar1229
Accepted Solution
problem with load combination
426 Views, 7 Replies
07-02-2012 06:28 AM
dear all
kindly  review  pic1/2
i have problem with load combination  ,at  first I used  nonlinear analysis but when stop it and  use full automatic combination after that no loads in case dialog, kindly help us
Please use plain text.
Product Support
Rafal.Gaweda
Re: problem with load combination
07-02-2012 06:37 AM in reply to: rodainnajjar1229
Automatic combinations are generated in linear model only
or use Manual Combiantion generator
Rafal Gaweda
Valued Contributor
rodainnajjar1229
07-02-2012 07:00 AM in reply to: Rafal.Gaweda
can we change anlysis type ??
Product Support
Rafal.Gaweda
07-02-2012 07:05 AM in reply to: rodainnajjar1229
Yes, if there is no nonlinear object \ element \ property in model.
Rafal Gaweda
Valued Contributor
rodainnajjar1229
07-02-2012 10:30 PM in reply to: Rafal.Gaweda
dear sir
kindly find attached file
i tried change anlysis type but i can t
Product Support
Artur.Kosakowski
07-03-2012 12:11 AM in reply to: rodainnajjar1229
You need to switch off the aux case definition.
Artur Kosakowski
huynhhoangvt
06-15-2014 06:42 AM in reply to: rodainnajjar1229
I have the same problem.i can not  load combination.i have been using EN 1990 : 2002 for project.Please advise!
Product Support
Rafal.Gaweda
06-16-2014 12:01 AM in reply to: huynhhoangvt
