dear all
kindly review pic1/2
i have problem with load combination ,at first I used nonlinear analysis but when stop it and use full automatic combination after that no loads in case dialog, kindly help us
Solved by Artur.Kosakowski. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Automatic combinations are generated in linear model only
or use Manual Combiantion generator
Yes, if there is no nonlinear object \ element \ property in model.
dear sir
kindly find attached file
i tried change anlysis type but i can t
You need to switch off the aux case definition.
I have the same problem.i can not load combination.i have been using EN 1990 : 2002 for project.Please advise!
